Useful C utility
Useful C utility
Path: utzoo!watmath!clyde!cbosgd!ulysses!allegra!bellcore!decvax!tektronix!uw-beaver!info-mac
Subject: Useful C utility
Date: Mon, 24-Dec-84 21:41:50 EST
Article-I.D.: uw-beave.297
Posted: Mon Dec 24 21:41:50 1984
Date-Received: Wed, 26-Dec-84 01:57:26 EST
Lines: 42
For all those Mac users on ArpaNet TACs trying to use BinHex:
You probably know that you can not easily use macput and macget through the
TAC. What you can do is to read the BinHex program into a MacTerminal
document, but wait.... The TAC does funny things with trailing blanks. It
was suggested that if you append a vertical bar (|) to the end of each line
BinHex would not mind, therefore the trailing spaces would not be a
problem.
Here is a tiny C program (which can be used as a filter) to append the
vertical bar to the end of every line.
#include
main()
char s[100];
for (;;) {
if (gets(s) == 0)
exit (0);
printf ("%s|\n", s);
Once you compile this program (I called it hexfilter), you can use it like:
$ cat freeware.hcx | hexfilter > freeware.bar
- or -
$ hexfilter freeware.bar
You can then "cat" freeware.bar into a MacTerminal document and run the
BinHex program to convert it into a Mac application. Mac Get/Put not
required.
Hope this helps.
joel
