desk accessory woes
desk accessory woes
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxn!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: desk accessory woes
Date: Fri, 21-Dec-84 14:00:10 EST
Article-I.D.: uw-beave.261
Posted: Fri Dec 21 14:00:10 1984
Date-Received: Sat, 22-Dec-84 03:16:55 EST
Lines: 16
I had some funny trouble installing desk accessories, using RMOVER and the
DAS file from the SUMEX archive ... when I tried to transfer a
resource, it would show up in the system file as a 0-length thing with ID=-1.
I finally cured everything by throwing away that system file and replacing
it with a fresher copy. I noticed that there were many bizarre resources
hanging around in the old system file, from icons of transient applications to
old fonts, etc. Is there a limitation on what the system file can hold?
Is there an easy way to clear out old garbage from the file, or is it best
to throw it away and start afresh occasionally? The offending system file is
on a disk I use for terminal emulation, BINHEX conversions, etc., so it gets
a lot of use....
DAS now seems to be fine except for missing the JOURNAL accessory (which I
can get from the other guided tour disks anyway)....
-- Z
