New Toner Tuner Demo
Download: http://archive.info-mac.org/cfg/toner-t ... 0-demo.hqx
Enclosed is the Toner Tuner Demo. Please check our web page at
http://www.working.com to see if this is the latest version.
Toner Tuner, one of the Working Software Printing Utilities, allows you
to save toner or ink when making draft prints. It works by printing
drafts in light gray. It works best with PostScript printers but also
works with most QuickDraw printers.
This demo works just like Tuner Tuner, but it prints obnoxious
information in the center of each "Toner-Tuned" page :-) :-). This only
happens when you turn Toner Tuner on in the Print dialog - it won't
affect your regular printouts.
To try out the demo, drag the Toner Tuner onto your System Folder, then
restart your Macintosh.
After restarting, print a document from one of your applications. Toner
Tuner adds some items to the print dialog. Use the slider bar to adjust
the print darkness, and check the "Use TT" checkbox to turn it on for
this print. The slider bar setting is remembered between prints.
Shortcut: hold the Option key when you press Return, or click Print, to
turn Toner Tuner on.
Secret Stuff for Advanced Users: Use ResEdit to edit the "TTPf"
resource in Toner Tuner to set the "Use TT" checkbox default to on. The
installer for the real product allows this as an option.
* Printer Compatibility
Toner Tuner works with most printers, but some printers will not respond
to Toner Tuner's command to lighten their printouts.
HP DeskWriter owners must use version 2.2 of the DeskWriter driver
software on black and white DeskWriters. Later versions of the black
and white DeskWriter, and all versions of the color DeskWriter do not
dim their printouts.
* Where to get it:
Toner Tuner is available from:
Working Software Inc. PO Box 1844 Santa Cruz, CA 95061-1844 (408)
423-5696 (408) 423-5699 Fax (800) 229-9675
[email protected] America Online WorkingSW
