Toggleator - is an AppleScript which toggles between your normal working screen resolution and 640x480. Once screen has been resized toggleator resizes open application windows to the proportionate size that they were in the previous resolution. Especially useful if you constantly toggle between two resolutions while creating webpages. Works with all applications that understand AppleScpript window commands such as FileMaker Pro, Netscape and others.
