INFO-MAC Digest V3 #46
Subject: INFO-MAC Digest V3 #46
Date: Fri, 4-Oct-85 02:02:34 EDT
Article-I.D.: uw-beave.1616
Posted: Fri Oct 4 02:02:34 1985
Date-Received: Sat, 5-Oct-85 06:34:53 EDT
Lines: 275
INFO-MAC Digest Friday, 4 Oct 1985 Volume 3 : Issue 46
More information about writing printer servers
MAC GPIB interface .. query
[question] Menu Clock and Hyperdrive 20
List of applications for AppleTalk ?
Deluxe Music Construction Set [query]
MacTerm Keycap mods?
Cryptography [query]
Kermit for the Mac
Kermit Docs
Date: 29 Sep 1985 12:40-EST
Subject: More information about writing printer servers
In response to my request for printer driver info, I received the following
from leo@Apple. Would you please place it into the printer driver informa-
tion file you created? (I checked with leo and he said it was OK--he didn't
send it out to the info-mac because he thought that most people would not
be interested.)
-Mark
From leo@APPLE Mon Sep 23 20:31:51 1985
Date: Wed, 18 Sep 85 01:19:13 pdt
Posted-Date: Wed, 18 Sep 85 01:19:13 pdt
To: mss%dartvax%dartmouth.csnet@CSNET-RELAY
Subject: Printer Support for the Rest of Us
Mark;
Here's a quick description of the Mac's Printing Architecture (and I DO use
the word architecture somewhat loosely).
There are two ways to print, known as the high-level and low-level printing
interfaces. In the high-level printing interface, the program calls all
those printing routines defined in Inside Mac, like PrOpen, PrOpenDoc,
PrOpenPage, and so forth, and gets back a printing GrafPort. The program
then calls QuickDraw routines to draw into this GrafPort, but instead of
being drawn in some BitMap somewhere, the drawings come out on the printer.
If a program is using the low-level interface, then instead of making the
calls to PrOpenDoc, it makes control calls on the .Print driver (driver
refNum -3). These calls have a csCode parameters that gives the type of
control call being made, which are the types of calls you mentioned: Here's
a BitMap, here's a stream of text, etc.
A single program never uses both levels of the interface. The sampling of
real programs is that MacPaint uses the low-level interface, and everybody
else uses the high-level interface.
When people refer to the ImageWriter driver, they're usually referring to
the ImageWriter resource file, which actually contains two pieces of code,
corresponding to the two levels of interface: one is a driver, as per the
device manager, that supports the low-level interface. The other thing in
the printer resource file is a series of PDEF resources (fairly undocumen-
ted) that contain the code to implement the high-level interfaces. The way
that the high-level interface is implemented is by installing a new set of
procedures in QuickDraw's StdProcs (in QuickDraw manual, pg. 70) that get
called whenever the application draws into the printing grafPort.
The low-level interface provided by the driver is pretty much as straight-
forward as you mentioned. It gets a few more control calls then just
BitMap, chars, and carriage return; there are also control calls for
OpenDoc, OpenPage, etc.; but basically, the low-level one is simple.
The only people who have written real-live Printer Drivers, as far as I
know, are 1) Apple, 2) Aldus, and 3) Orange Micro is trying. There may be
some others... Macintosh Tech Support, I believe, has a Tech Note with more
details on writing a printer driver, but I don't know how you'd go about
getting it from them (though their number is 408 973 3400)(if you have any
other connection, try it).
Unfortunately, having looked at the task before (and with the advantage of
having access to the source of the ImageWriter driver), writing a real
printer file is a heavy-duty task; not impossible, but not a two-weekender.
I think just doing the low-level interface, giving you MacPaint at least,
wouldn't be too bad...
Good luck!
Leovitch
Leo Hourvitz
Apple Computer, Inc.
[This entire message has been archived as
[SUMEX]PRINTER-DRIVERS.INFO. --RMA]
Date: Thu, 3 Oct 85 14:57:50 mdt
Subject: MAC GPIB interface .. query
Reply-to: [email protected] (Scott Chesney)
Is there an available Macintosh GPIB controller? It would be nice to be
able to do instrument control with a Mac as opposed to the more expensive
H-P or Tektronix systems.
Thanks in advance,
Scott (the sorcerer's apprentice) Chesney
ihnp4!lanl!hsc.UUCP [email protected]
Date: Wed, 2 Oct 85 11:46:47 edt
Subject: [question] Menu Clock and Hyperdrive 20
I am having trouble using the MenuClock posted here recently with my
Hyperdrive 20. I can use the MenuClock if I boot off floppy as a normal
512k mac, but it will not work when I use the Hyperdrive system files (it
crashes with a fuzzy screen). It will work, however, on a Hyperdrive 10
which is several months old.
Has anyone else had this problem/come up with a fix?
John T. Kohl
UUCP: ...!mit-eddie!mit-athena!jtkohl
ARPA: [email protected]
Subject: List of applications for AppleTalk ?
Date: 02 Oct 85 09:32:49 EDT (Wed)
We have been using Appletalk for the last three months, but have not come
across too many applications to run on this network. In fact, we use it
only for sharing the LaserWriter. So I would like to know the list of
applications that other people are using on AppleTalk.
Thanks in advance.
-guru
PS: Some examples of Applications that I have in mind are say mail, file
transfer etc.
Gurudatta M. Parulkar
University of Delaware
Department of Computer and Information Sciences
Newark, DE 19716
ARPA: parulkar@udel-dewey
CSNET: parulkar%udel-dewey@csnet-relay
UUCP: ...!harvard!parulkar@udel-dewey
Subject: Deluxe Music Construction Set [query]
Date: Sun Sep 29 09:49:08 1985
Has anyone out there seen a copy of the Deluxe music construction set for
the Macintosh yet? I understand they have a MIDI option now that lets you
play music through a MIDI equipped synthizer. This is a great feature but
a musician friend of mine wants to know if you can RECORD music comming in
through a MIDI and then edit it and play it back or print it.
Basically he wants to play a piece of music on his synthizer, record it
with a music program and then be able to edit, print or replay it.
The add for Deluxe MCS says you can play back music through the MIDI port
but it does not say if you can record. Does anyone know for sure?
Please reply directly...I don't get info-mac regularly
Greg Corson
{ihnp4 | ucbvax}!pur-ee!kangaro!milo
ARPA: kangaro!milo@[email protected] or kangaro![email protected]
Or leave a message to the sysop on The Connection (219) 277-5825
Date: Sat, 28 Sep 85 01:43:59 pdt
Subject: MacTerm Keycap mods?
Has anyone tried to modify the macterm keycaps? I have the doc but in my
infinite laziness I wondered if anyone else got there first. I need VT-100
arrow keys. I thought I'd put them on command-6 to 9 plus cmd-0 for
'home'. But if anyone else has gotten there first could we trade resources
maybe?
Also, the system I use at school here is a Prime 9955 (the machine I need
arrow keys for). I want to up-and-download files. People, I DON'T want to
rewrite mac-put-and-get in FORTRAN IV!!!! Has anyone else heard of any
system software for mac-Prime usage? Lets see, DO, CONTINUE, FORMAT, LET,
GOTO. Here we go!!!!!!!
Thanks for all. Andy Stadler c/o SAJ@ACC
Occidental College
Subject: Cryptography [query]
Date: Tue Oct 1 20:04:11 1985
I am in the process of writing a cryptography program for the Macintosh
that encrypts and decrypts Mac files and applications. I considered using
the Data Encryption Standard but I discovered that this standard,
implimented in software, will probably be too slow to be useful (the Hippo
C DES encryptor takes 120 seconds to encrypt a 12k file). Obviously, if
the encryptor runs too slow people won't bother using it so I had to come
up with a different means of encrypting the file that was faster.
I have settled on using a software implimentation of a "rotor" machine such
as an enigma or ECM because a software version of one of these machines is
very fast.
I am looking for someone who is "into" cryptography who could give me some
idea of how secure the method I am using is. I basically want to make sure
that I haven't overlooked any simple way a smart person could use to crack
the code. If you can help me figure out how secure my algorithim is,
please contact me.
I should mention that I have researched this problem fairly throughly...so
if you are not somewhat experinced in cryptography you probably won't be
able to help much.
Greg Corson
ARPA: kangaro![email protected] or kangaro!milo@[email protected]
P.S. If anyone knows of any software company that might want to sell this
kind of product, please let me know. I am looking for a publisher.
Date: Wed, 2 Oct 85 7:32:26 EDT
Subject: Kermit for the Mac
Here's a later version of Kermit for the Mac from Columbia. It is version
0.8(33). ENJOY !
[This replaces the older [SUMEX]CKMKER.HQX. --RMA]
Date: Wed, 2 Oct 85 7:36:03 EDT
Subject: Kermit Docs
Here is the documentation that goes with MacKermit version 0.8(33). Run it
through BinHex 4.0 and then use PackIt to unpack. It contains five
MacWrite Documents:
Read Me
Beware
History
IBM (yuck) Mainframe settings
Normal Settings
ENJOY
[The documentation has been placed in [SUMEX]CKMKER.DQC. --RMA]
