Mac Pascal: more information after a semester's use
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Mac Pascal: more information after a semester's use
Date: Thu, 3-Jan-85 23:28:27 EST
Article-I.D.: uw-beave.343
Posted: Thu Jan 3 23:28:27 1985
Date-Received: Fri, 4-Jan-85 08:10:06 EST
Lines: 89
I sent a message about a month ago describing the logistical horrors we
had this semester in using Macs and Lisas for our first 3 courses. We
have now finished the semester, and have gotten back comments from the
students. I am not going to comment again on the items I discussed
before. It does appear that the students liked the Macintosh, even with
the problems. Our impression is that for the first course Mac Pascal
took more time to learn than what we used before, which was Cornell's
PL/C Synthesizer. The Synthesizer made it nearly impossible to make
syntactic errors. Rather than type text, you hit keys to create various
program constructs. When you did have to type (as with expressions),
they would be parsed immediately. Our faculty felt that this allowed
them to concentrate on program design and data structures. This was a
pleasant contrast to the normal experience in first courses, where much
of the time is spent on syntax. Mac Pascal is better than the typical
timesharing system. It does detect some kinds of errors in the editor.
However there are still cases where you don't find a missing semicolon
until you run the program. As with any compiler, there are cases where
the error messages don't help a novice very much (though the error
messages are quite good compared to what we see in normal compilers).
Mac Pascal has some advantages over the Synthesizer in debugging
facilities. It is my impression that most of our students do not use
debugging facilities, so that was probably a minor benefit. The net
effect is that our first course spent noticably more time dealing with
syntax than it had before. However it is still good compared to most
other software.
The second course was using UCSD Pascal previously. (The PL/C
Synthesizer could not handle large enough programs.) Mac Pascal is a
dramatic improvement over that. The general quality of its user
interface, the language that it implements, and it state of debuggedness
(??) are all considerably superior. It is possible that the UCSD Pascal
we were using is not typical of the current product. It was for the
Terak, which is a fairly old machine. We have some reason to think that
newer releases of UCSD Pascal were not ported to the Terak. As you might
expect, the limiting factor in using Mac Pascal is memory in a 128K Mac.
The assignments had to be carefully designed and tested to make sure
that they did not exceed memory. Both array sizes and recursion depth
could cause trouble.
My impression is that the changeover to Mac Pascal helped the second
course more than it hurt the first course. This is particularly true
because it allowed us to use the same system in both courses. In
summary, I recommend Mac Pascal for instructional use. However I think a
full syntax-directed editor would be a real improvement for the first
course. And I recommend using 512K Macs.
Now for the bad news. We have continued to have problems with Pascal
diskettes becoming unbootable. Between Apple and Think, we have heard
the following hypotheses:
- there is a bug in Mac Pascal, that causes it to garbage part of the
diskette.
- something about the copy protection scheme used by Think causes
diskettes to be damaged. Apparently both Apple and Think
believe this has caused some of our damage. However Think does
not believe that it accounts for most of the problems. (Vendors
who are considering fancy copy-protection schemes should think
about this. I would think very carefully before using any
scheme that involves nonstandard formatting or damaged sectors.
Think believed that their scheme was safe. So did Apple.
Neither do now.)
- something about Mac Pascal makes it more sensitive to disk alignment
problems.
Our evidence supports the 3rd alternative, though they are by no means
mutually exclusive. We don't think it is a simple software bug, because
the problem seems to occur more often at certain sites, and in a couple
of cases we have been able to localize it to a particular machine. When
Mac Pascal is used long enough on one of these machines, it becomes
unbootable. Unfortunately we are unable to find out which machines are
involved, because of the way the diskettes are distributed. The most
certain way to solve the problem would be to check alignment on all of
our diskettes. I suspect that such a check would show a few machines
that are marginal, and that if they are readjusted our problem would
disappear. We understand that Think is working on the problem. Apple is
very concerned, but they are not concerned enough to come check
alignment on our machines. Unfortunately, checking drive alignment seems
to be a multi-hour procedure. It has been claimed that Sony has given
Apple a diskette that allows alignment to be checked almost instantly,
but no one at Apple seems to be able to find this diskette. So the net
result is that neither Apple nor Think has been able to do anything
about the problem. We are hoping that it will not cause as much of an
effect in the Spring semester. Each student will have his own diskette.
There will be much less swapping of diskettes, since they will keep
their current assignment on their Pascal diskette. We think that this
decrease in disk usage will help the problem. Of course it is also
possible that instead of 50 diskettes to get damaged we will now have
1000, and our problem will just become that much more unmanagable.
