the-mouse-2b.hqx
the-mouse-2b.hqx
Download: http://archive.info-mac.org/cfg/themouse-2b-11.hqx
TheMouse2B v1.1
Matthew Dolan
© 1999, Tri-Bar
http//www.tribar.dabsol.co.uk/
TheMouse2B is a control panel which allows you to configure the second
button on your PS/2, USB or ADB mouse. TheMouse2B allows you to configure
the second button to act like a single-click, double-click or even a
click-lock. TheMouse2B can also be configured so that as the mouse button is
held down a modifier key such as control or option is "held" down.
TheMouse2B is shareware, and as such if you continue to use it for more than
30 days you should pay the $10 license fee (£5 UK).
Requires:
2 or more button mouse (works with PS/2, USB and ADB mice)
System 7.0 or better (works best with MacOS 8.0)
