Control panel bugs
Control panel bugs
Path: utzoo!watmath!clyde!burl!ulysses!mhuxr!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Control panel bugs
Date: Mon, 14-Jan-85 04:56:48 EST
Article-I.D.: uw-beave.414
Posted: Mon Jan 14 04:56:48 1985
Date-Received: Tue, 15-Jan-85 01:44:07 EST
Lines: 29
I just read Cowan's message on my Mac, and activated the control panel.
My date, untouched by man or mouse, read Jan 12, 1985, as it should,
not 1984.
There is a problem I've been meaning to report on for months now.
I have a habit of slowing my keystrokes, including the down phase,
when thinking while writing. This interacts badly with auto-repeat,
so I prefer to leave the turtle/bunny parameter on 0, the turtle
rail, to suppress the repeat.
This parameter is not initialized properly when programs are started
from disks inserted into a newly powered up Mac. For instance, if I
insert a disk, wait for it to boot, then lean on the "A" key, the disk
is renamed to aaaaaaaaaa... If I run MacWrite, I'm likely to type
ccooommpppuutteeerr instead of computer; same problem with most other
programs. When I fetch the control panel the repeat parameter is where
I left it, at turtle 0. If I simply close the control panel, the problem
is still there. However, if I mouse over to this parameter's slider and
simply click it at its 0 setting, even without moving it, the auto repeat
disappears until the next cold boot. This problem exists on all versions
of the system I've used (the original, the one on with MacWrite 2.2,
the one on the MacDraw/MacProject disk). My experience is only with
skinny Macs so far.
Also, I wish MacPaint and MacDraw could rotate objects by arbitrary
angles, but that's another story.
-- Hans Moravec
