The MacLocksmith 2.4.0; file-folder-disk protection
Post by Info-Mac » August 29th, 1999, 9:00 am
Download: http://archive.info-mac.org/cfg/the-mac ... ith-24.hqx
The MacLocksmith is an useful application to save your files from
indiscreet eyes. It protects your files/folders quickly by using a very
strong encryption method and a password. The MacLocksmith supplies also a
second, soft and fast, protection system. You may use it in situations of
already good security level.
The MacLocksmith allows you to create Cryptet. Cryptets are stand-alone
auto-decrypting applications containing one encrypted or protected file. A
Cryptet may decrypt the contained file or simply save it on disks.
Distribution of encrypted files is no longer a problem, now. You may create
FAT, PPC or 68k applications and choose a text file that will be used, by
created Cryptet, as custom About box.
The MacLocksmith can make also other actions:
- it locks/unlocks disks by software flag,
- sets/unsets lock bit of files,
- locks/unlocks names,
- shows/hides files and folders.
You may configure all actions of above through preferences, you may also
set the preferences on the fly, before work, simply holding down option key.
Other preferences options:
- don't encrypt invisibles,
- ignore system resources,
- only folder's contents, ignore the folder itself,
- scan disks.
The MacLocksmith is Internet Config, Drag Manager and Navigation Manager
aware, moreover it's Appearance savvy.
It requires at least System 7 to run.
What's new in 2.4.0 version
Unique password option. Only folder contents option. Don't encrypt
invisible option. Ignore System Resources option. Windows position saving.
Some graphic change. Better support of Appearance in menus. Better check
for low application memory. Scan disk disables encryption and vice-versa.
Improved Internet menu. More well-defined error messages. Navigation
Manager aware. Recompiled by using the newest compiler. Addresses update.
Removed registration form from About Box. Added Registrations folder. Added
Support folder. Removed custom font. Code optimized for better
performances. All code revisited.
