Program Name : The Lightsaver USA
Program Type : System extension
Distribution : shareware ($5)
Author : Francesco Meschia
The Lightsaver is a small system extension which takes care of adjusting
the system clock for you, when entering or leaving daylight saving time.
This release is intended for users in the U.S.A. or in other countries
adopting U.S. rules for DST.
The Lightsaver works silently at startup time; it does not slow down your
Mac nor uses a single byte of your valuable RAM.
