Teoma Plugin for Sherlock
Download: http://archive.info-mac.org/cfg/teoma.hqx
This plugin enables Sherlock to search Teoma, a new and very powerful
Internet search engine.
Please notice that I am not affiliated with Teoma Technologies in any way.
This plugin will automatically update itself if a newer version becomes
available. If it doesn't work right away after downloading, an update may
be available. Please wait three days (after which the automatic update
will occur), or check out my web site below for an update.
This and other Sherlock plugins can be downloaded from
http://www.aardvark.at/software/
