Hard disk info
Hard disk info
Post by Info-Mac » August 28th, 1984, 4:38 am
Path: utzoo!watmath!clyde!burl!mgnetp!ihnp4!houxm!houxz!vax135!cornell!uw-beaver!info-mac
Subject: Hard disk info
Date: Mon, 16-Jul-84 15:12:59 EDT
Article-I.D.: uw-beave.1223
Posted: Mon Jul 16 15:12:59 1984
Date-Received: Tue, 17-Jul-84 02:12:39 EDT
Lines: 23
I recently got to see both the Davong and Tecmar hard disk systems.
Here's the scoop:
They both use the RS422 port, as far as the Mac is concerned, they
are AppleBus devices. Neither can be booted directly, you must insert a
'master' disk first. Once they are up, however, the hard disk supports the
system, so the master can be put aside (until you get a system error). Both
of the systems are slow as far as hard disks go, however, the Davong is
faster than the Tecmar, which is a noticable improvement over the internal
floppy. The Tecmar supports removable 5-meg cartriges, the Davong supports
larger storage sizes (10, 15, 21, 32, 40 meg). The Davong also seems to be
more reliable, but it does have its drawbacks. For one, the Tecmar sports
an additional 9-pin connector on its back, unlike the Davong. In addition,
the Davong is quite a bit wider than the Mac, the Tecmar being slightly
higher, but matching the Mac's footprint. Finally, the Davong is more
expensive, a ballpark figure showed the Davong to be about $400 more for
units of the same size. I prefer the Davong, however, I am hoping for a
unit that will be able to go onto the external drive connector. As a side
note, it is rumored that Haba Systems will be producing a 1meg version of
the external disk drive.
_emt
