Subject: Odd bug in MacTerminal 1.1
Date: Mon, 15-Oct-84 07:16:12 EDT
Article-I.D.: uw-beave.1942
Posted: Mon Oct 15 07:16:12 1984
Date-Received: Tue, 16-Oct-84 06:12:56 EDT
Lines: 16
I don't know if Apple is still monitoring this list, but here's a weird
bug that I noticed while testing macput as per my previous message (this
is a completely different problem). I have the Calendar accessory installed
in my system disk, but I do not have files named Calendar on either my
system or MacTerm disks. When I attempt to download the calendar.rsrc file
with the command "macput -r calendar.rsrc" it works fine and creates
calendar.rsrc on my MacTerm disk. However, if instead I say
"macput -r calendar" (which should be equivalent, except for the name of
the file created on my disk), the download hangs at 0%, and I have to
reboot. This only happens with calendar, and it has happened four times.
Both forms of the command work with other applications.
Could there be some weird interference between the accessory name and the
download file name?
-Barry Eynon
