FileVision
FileVision
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!ihnp4!houxm!houxz!vax135!cornell!uw-beaver!info-mac
Subject: FileVision
Date: Tue, 17-Jul-84 16:52:24 EDT
Article-I.D.: uw-beave.1239
Posted: Tue Jul 17 16:52:24 1984
Date-Received: Wed, 18-Jul-84 03:49:19 EDT
Lines: 47
I had the opportunity to play with a program called FileVision from
TELOS software recently. It is a visual database system which combines
graphic and textual information.
FileVision is object oriented. Objects are drawn on the screen using
tools similar to MacPaint and MacDraw. Types of objects are given names
and information relating to the object can be added to the database by
defining a form. Forms may contain up to 30 fields and you may define
up to 16 types of objects. Since the program is a radical departure
from what many of us have known of database software, an example may
help explain it.
One tutorial in the preliminary manual is a map of the U.S. By
double-clicking on a state with the mouse, information about the state
such as state name, population, and average income is displayed in a
"form" format. The form can be modified and the tutorial has you add a
field to indicate if you have visited the state. It is possible to
highlight all of the states or just the states meeting certain selection
criteria such as only the ones you have visited. You may have up to 4
conditions for selections. Relations include equal, greater than, less
than, or unequal and you may use wildcards in the selection. Multiple
object types can exist in the same drawing file and these can be
individually highlighted or only certain types shown. A second more
extensive tutorial of a wine cellar database is furnished in the manual.
Examples of applications mentioned in the manual include a star map,
anatomical drawings, a seating arrangement, and a parking lot map. Any
application that can benefit from a graphic display is a good candidate
for FileVision. The printout capabilities allow printing of the drawing
file, selected portions of the drawing, ordered lists, and formatted
reports including 1 up labels.
I find that FileVision is a tremendously innovative product that
demonstrates the power and flexibility of the Macintosh. It follows the
conventions of the Macintosh interface very closely. The software is
disk-based so the size of the file is not limited by internal memory.
This is *not* a rework of old software. If FileVision is the first
application of this type for the Mac, it is difficult to imagine the
software for the Mac in three more years--when I first saw VisiCalc, I
thought it was tops.
Scheduled release is August, 1984. I'll try to answer questions that
anyone may have.
John
