TechTool 1.1.9
TechTool 1.1.9
Download: http://archive.info-mac.org/cfg/tech-tool-119.hqx
TechTool is the acclaimed utility that solves those incurable problems
which elude other utilities. With TechTool you can:
* Analyze your system file for damage.
* Save file comments before clearing desktop database.
* Zap the entire PRAM chip.
* Delete the desktop file, the better alternative to rebuilding.
* Clean your floppy drive (use with drive cleaning disk).
* See the date your computer was manufactured and how many hours of use
it has had.
* View, print and save a multitude of information about your Mac.
* Ability to save desktop database(s).
* Employs TechTool Pro mandate restore routine.
New to version 1.1.9:
* Added support for US versions of system 9
* Added support for international versions of system 8.6
* Updated TechTool Pro information.
TechTool requires System 7.0 or above
Cost: None. Free gift from MicroMat Computer Systems.
