TDC 1.0
TDC 1.0
Download: http://archive.info-mac.org/cfg/tdc-10.hqx
TDC 1.0 is a stay-open applescript application, designed to go in the
startup items folder. it sits in the background and changes your desktop
picture every so often.
Fraser Speirs
