TattleTech 2.58 Update
Download: http://archive.info-mac.org/cfg/tattletech-258.hqx
TattleTech 2.58 replaces TattleTech 2.20
TattleTech is a System Profiler, Tech Support tool, and Bug Reporter
application. It was formerly called TattleTale.
2.58 addresses the following issues:
- System 8.1 compatability including HFS+ allocation block size
- Improved reporting of SCSI-3 devices
- Fixed a bug which prevented the proper reporting of the ethernet hardware
address the first time the Network report was run
- Fixed a dialog problem
TT reports over 850 informational items regarding your system and its
hardware and peripherals including the following: PCI Cards, PC (PCMCIA)
Cards, ATA/IDE Devices, Mult Processors/L2 Cache,PRAM, Gestalts,General HW
attributes,Volumes/Drives,Monitors,Nubus/PDS Cards, ADB devices, SCSI
devices,Traps,Applications,DAs,Fonts,INITs, and CDEVs. Also checks file
integrity.
Uses include learning about your Mac, pre-purchase feature verification,
reporting problems to vendors/product support, beta testing, disk-based
surveys, etc.
Shareware: $15 and up.
REQUIRES:
Mac+ or >
System 7.0 or >
