This archive contains the latest versions of the AppleScript applets Startup Log
and Shutdown Log.
Startup Log and Shutdown Log are AppleScript applets that log the date and time
of your Macintosh Systems startup and shutdown, respectively. The applets have
been modified to correct problems running the applets on non-US Macintosh
systems. The applets require AppleScript and the "Read/Write Commands"
scripting addition.
