Re: Why is the Mac so slow?
Post by Info-Mac » December 20th, 1984, 3:01 am
Subject: Re: Why is the Mac so slow?
Date: Tue, 27-Nov-84 01:23:26 EST
Article-I.D.: uw-beave.2329
Posted: Tue Nov 27 01:23:26 1984
Date-Received: Wed, 28-Nov-84 03:51:53 EST
Sender: root@uw-beave
Lines: 15
The answer is that there is no good reason for MacPascal to be slow.
Other languages, particularly MacForth and the C compilers run at a
blazing speed on the Mac. I suspect that the Macintosh Pascal system is
a little too large to fit comfortably on a 128k Mac, and therefore does
a lot of disk swaps. If you think about it, MacPascal has a pretty
extensive set of library routines. This is generally considered good in
a compiler, but MacPascal is interpreted, and so has to load them into
memory when they are called. I'm willing to bet that this is a lot of
the initial load and run time.
We can hope that a compatible Pascal compiler will arrive to supplement
MacPascal. Then we can hope for high speed AND development ease.
Kurt
