Apple 1200 modem, mouse playing field
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!houxm!houxa!vax135!cornell!uw-beaver!info-mac
Subject: Apple 1200 modem, mouse playing field
Date: Thu, 19-Jul-84 15:47:36 EDT
Article-I.D.: uw-beaver>.1261
Posted: Thu Jul 19 15:47:36 1984
Date-Received: Fri, 20-Jul-84 04:37:39 EDT
Lines: 31
Regarding Dan Feldman's query on the Apple 1200, I found two quirks with it
most upsetting. One could be fixed, the other caused me to return it in swap
for a Hayes 1200.
The Apple 1200 had the most upsetting habit of dropping carrier when I hit the
"Enter" button to send a BREAK down the line. This is correctable by changing
the position of the third DIP switch, and upon close reading is even suggested
by the manual (but was unknown to the local dealership). But, as shipped and
documented for "normal" use by Apple, a BREAK is a big lose.
The Apple 1200, nominally Hayes compatible, is also defined in its own manual
to react to the escape sequence (plus-plus-plus, by default) by DROPPING
CARRIER and turning its attention to the Apple (away from the communications
line). If the purpose of the Attention Code was to (say) change parity and
return to the communication (by means of "AT O" -- Attention, return Online),
then the purpose is not ever to be achieved. This, however, is what the Apple
manual says will happen, it does, and Apple says you can't "fix" it. The Hayes
manual specifically says that the sequence will NOT drop carrier, it does not
drop carrier, and it has proven highly useful since acquisition. So much for
"compatible."
Incidentally, anybody contemplating either should note how flimsy the power
connector at the back of the Apple modem is, and also how bulky the power
transformer is -- mine used up THREE plug-spaces on my Orange power
protector/filter! My Hayes transformer only uses up two, still not great.
About the playing fields for our mice: I have a kitchen cutting board of very
slightly roughened plastic (stippled by the manufacturer, not sliced by me),
about 1/3 inch thick and roughly 9x12" -- works great!
