Switcher_PowerUp135.sit
Download: http://archive.info-mac.org/cfg/switche ... up-135.hqx
Switcher PowerUp works with MacOS 8.5 or later Application Switcher.
Use it to access most of the Application Switchers features. Switcher
PowerUp requires a Mac running OS 8.5 or later.
Switcher PowerUp is freeware.
- Mitch Crane - [email protected] -
http://www.mindspring.com/~sublink/swpu.html
