This is a simple program which will replace your Startupscreen with one
randomly chosen from a folder of picture files. It will also optionally
scale, crop and/or add a customizable text message to the image before
saving it as a Startupscreen. Put in the startup items folder for maximum
effectiveness. Requires a PowerPC processor and 'bout 32 megs RAM.
Quicktime and System 7.5.5 or later recommended.
