Stella's Mover will help people moving from a Macintosh to a Windows
PC (though they be sinners). It will check file names for non-Windows
characters and rename them to an underscore character. It will also
add the appropriate file extension, (such as .xls or .doc). Please
contact [email protected] with any questions. This software is $15
Shareware. It requires MacOS 7.5 and AppleScript support.
