StartupScreen Randomizer 1.1
Post by Info-Mac » February 19th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/startup ... omizer.hqx
This is a simple program which allows you to randomly make startupscreens
from a folder of pictures you may have sitting around your hard drive. All
you do is open it up, configure a few simple options and let the
StartupScreen Randomizer randomly build your startupscreens. Options
include the ability to scale and/or crop your images, put a colored
background around them or add a customizable text message on them
(perhaps something to the effect of 'Welcome to my computer'). It's nearly
transparent to you the user.
Numerous bug fixes and improvements from 1.0 include the now faceless (ie
background only, no ui for the randomizer) app so that it's not so
intrusive. Also much faster and more options for the text message.
