C version of MACIMP (* source code *)
Post by Info-Mac » September 22nd, 1984, 11:29 pm
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!ihnp4!zehntel!tektronix!uw-beaver!info-mac
Subject: C version of MACIMP (* source code *)
Date: Sat, 28-Jul-84 20:10:18 EDT
Article-I.D.: uw-beave.1350
Posted: Sat Jul 28 20:10:18 1984
Date-Received: Mon, 30-Jul-84 00:49:00 EDT
Lines: 165
Here is the UNIX/C version of MACIMP (also on {SUMEX-AIM}MACIMP.C).
Thanks to Dan Winkler of Harvard for this version.
This filter converts MacPaint files into Impress files
for printing on an Imagen laser printer. Based on MACimp
for Tops-20 by Ed Pattermann, Stanford.
Usage: macimp
#include
#define MAG_POWER 1 /* can be 0, 1, or 2 */
#define DOTS_PER_INCH 240
#define OPAQUE 3
#define OPERATION_TYPE OPAQUE
#define HSIZE 18
#define VSIZE 23
#define MAC_HEADER_LENGTH 512
#define PAD_BYTES 1152
#define LOBYTE(number) ((char)(number & 0x00FF))
#define HIBYTE(number16) ((char)((number16 >> 8) & 0x00FF))
#define PATCH_SIZE 32
#define PATCH_BYTES 4
typedef char patch[ PATCH_SIZE ][ PATCH_BYTES ] ;
main()
write_imp_init() ;
throw_away_mac_header() ;
process_data() ;
write_imp_end() ;
fflush(stdout) ;
process_data()
int data_byte ; short repeat_count, byte_num ;
while ( (data_byte = getchar()) != EOF )
if ( data_byte > 127 )
repeat_count = 256 - data_byte + 1 ;
data_byte = getchar() ;
for (byte_num = 0 ; byte_num = PATCH_BYTES )
patch_col = 0 ;
if ( ++ patch_num >= HSIZE )
patch_num = 0 ;
if ( ++ patch_row >= PATCH_SIZE )
patch_row = 0 ;
write_patches ( patches ) ;
patch * patches ;
short patchnum, patchrow, patchcol ;
for ( patchnum = 0 ; patchnum < HSIZE ; patchnum ++ )
for ( patchrow = 0 ; patchrow < PATCH_SIZE ; patchrow ++ )
for ( patchcol = 0 ; patchcol < PATCH_BYTES ; patchcol ++ )
putchar( patches[ patchnum ][ patchrow ][ patchcol ] ) ;
short bytenum ;
for ( bytenum = 0 ; bytenum < MAC_HEADER_LENGTH ; bytenum ++ )
( void ) getchar() ;
write_imp_init()
char *getenv();
char *ctime(), cimptime[26];
long time(), imptime;
imptime = time(0); /* get time in internal form */
strcpy (cimptime, ctime(&imptime));/* put time in string form */
cimptime[24] = '\0'; /* nullify \n in time string */
printf("@DOCUMENT(LANGUAGE IMPRESS, NAME \"MacPaint Document\"") ;
printf(", OWNER \"%s\"",getenv("USER"));
printf(", SPOOLDATE \"%s\")",cimptime);
/* SET_ABS_H */
putchar( (char) 135 ) ;
putchar( HIBYTE( (short) DOTS_PER_INCH )) ;
putchar( LOBYTE( (short) DOTS_PER_INCH )) ;
/* SET_ABS_V */
putchar( (char) 137 ) ;
/* SET_MAGNIFICATION */
putchar( (char) 236 ) ; putchar( (char) MAG_POWER ) ;
/* BITMAP */
putchar( (char) 235 ) ; putchar( (char) OPERATION_TYPE ) ;
putchar( (char) HSIZE ) ; putchar( (char) VSIZE ) ;
write_imp_end()
/* ENDPAGE */
putchar( (char) 219 ) ;
/* EOF */
putchar( (char) 255 ) ;
