Implications of Pascal copy protection
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: Implications of Pascal copy protection
Date: Thu, 11-Oct-84 00:29:37 EDT
Article-I.D.: uw-beave.1857
Posted: Thu Oct 11 00:29:37 1984
Date-Received: Sat, 6-Oct-84 05:19:39 EDT
Lines: 25
The scrapbook seems like a ideal place to store a library of Pascal procedures.
Then when a procedure is needed, it could be easily pasted into the program
at the proper place. However, Apples decision to copy protect Macpascal
puts a damper on this scheme. Since the active scrapbook is the one
on the startup disk, you will need to write to the valuable copy
protected disk. When the scrapbook gets large, you cannot eaisly
switch to another disk.
One workaround is to delete the finder from the original disk and startup
with another disk containing the scrapbook of interest. On a single
disk system, this would, I imagine, lead to a disk swapping nightmare
since I assume Pascal would need to go to its disk for its library
and the system disk for system resources. It might work OK on a
two disk system, but again, you have to be brave and delete files from
a copy protected disk.
A similar problem occurs with fonts. I can easily imagine wanting to
use other than the minimal fonts with Pascal. To do so, I have to
modify the orginal disk some way(Font mover, deleting finder, etc.).
Does anyone have any solutions to these issues? It's really a shame that
Apple did not try making this a very low price, unprotected product along
tfhe lines of Turbo-pascal. That is certainly the wave of the future.
