More MacPascal Complaints
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!mhuxj!houxm!vax135!cornell!uw-beaver!info-mac
Subject: More MacPascal Complaints
Date: Sat, 10-Nov-84 00:13:04 EST
Article-I.D.: uw-beave.2174
Posted: Sat Nov 10 00:13:04 1984
Date-Received: Tue, 13-Nov-84 04:38:56 EST
Sender: yenbut@uw-beave
Lines: 54
Standard Pascal says that there is no constant corresponding to the following
string variable:
VAR OneChar: PACKED ARRAY [1..1] OF CHAR;
That is because the language does not want to confuse strings with type CHAR.
The MacPascal documentation tells you that as an extension to the language they
provide you with string constants of length 1. The better thing to say would
have been, "Strings and type CHAR are now compatible types."
I noticed this when a student showed me the following IF/THEN/ELSE:
IF ch = ' A' THEN
OneThing
ELSE
AnotherThing;
The problem here is the fact that I am comparing ch (of type CHAR) with a string
variable of length 2 (because there is a stray space before the A). The student
was confused when the OBSERVATION window showed the variable CH with the value
'A' but MacPascal was executing the ELSE branch. This is another of those
places where proportional spacing proved to be a pain. The space above is much
more visible than it is in MacPascal.
This should have been flagged as a type conflict of operands.
Before I cover ARRAYs in my course I like to have students see what they can
do by manipulating a file character by character. For example, you might
want to uppercase an entire file by saying:
PROGRAM UpperCase (INPUT, OUTPU);
VAR ch: CHAR;
BEGIN
WHILE NOT EOF DO
BEGIN
WHILE NOT EOLN DO
BEGIN
READ (ch);
IF ch IN ['a'..'z'] THEN
ch := CHR (ORD (ch) - ORD ('a') + ORD ('A'));
WRITE (ch)
END;
READLN;
WRITELN
END
END.
I don't suggest using this program in MacPascal. First of all, INPUT and OUTPUT
are assigned to the terminal, so you have to explicitely CLOSE them and then
RESET and REWRITE to other files. Even so, this program is painfully slow even
on input files of just a few thousand characters. I just ran a sample execution
on a 2000 character file and found that it took 11.5 minutes.
