StartupQuote 1.3
StartupQuote 1.3
Post by Info-Mac » September 18th, 1998, 9:00 am
Download: http://archive.info-mac.org/cfg/startup-quote-13.hqx
StartupQuote displays a new quote at each startup. Unlike other 'fortune
cookie' programs, the quote is REALLY displayed at startup; no INIT,
a new StartupScreen file is simply built by the StartupQuote application.
StartupQuote is distributed as shareware ($10).
By registering at Kagi, you'll get an unlock code that will allow you to add
new quotes, remove or edit existing ones, import/export quotes text files.
Unregistered versions display the default quotes set.
Version 1.3 can customize the font used to display the quotes.
Version 1.2 added customizable background picture.
Version 1.1 added French/English interface.
StartupQuote 1.3 has English default quotes,
StartupQuote 1.3Fr has French default quotes.
The official StartupQuote web page is at:
http://www.pobox.com/~riff/shareware/st ... index.html
