Download: http://archive.info-mac.org/cfg/start-s ... -10-jp.hqx
This is the Japanese version of the StartScreenUp package.
The StartScreenUp1.0 extension is a little INIT to reload the
StartupScreen. This extension has been written to get rid of the password
dialogbox of "DiskGuard" or "FileGuard" by Highware cross over the
StartupScreen after the password has been entered.
All MacintoshOS based computers are able to show a StartupScreen during the
whole startup process. To create a StartupScreen you need a picture which
must be saved in a "PICT" Resource with ID 0 (use JPEGView, Grafikconverter,
PhotoShop, ClarisWorks, etc. ), and must be located in the systemfolder and
named "StartupScreen". Normally the Mac will show only one StartupScreen.
With StartScreenUp1.0 you can even view a second picture!
StartScreenUp1.0 patches no traps and after the boot process it uninstalls
itself so nothing remains in your system which could slow it down. Also no
compatibility problem should occur.
StartScreenUp1.0 is released free to let you know about CopyPaste, the
productivity tool for your Mac, downloadable from http://www.bridge1.com.
CopyPaste gives you ten clipboards instead of just one! How many times have
you found yourself going back and forth copying in one application and
pasting in a different application, wishing to yourself that you could copy
5-10 items at a time, then go to another application and paste each of
these items. Now you can! Type the usual keyboard command for copy or cut
and then any number between 1 and 9 before releasing the command key. Paste
works in the same way. In addition to the normal clipboard you now have
nine more.
