mackermit through a tac
Post by Info-Mac » December 19th, 1984, 11:42 pm
Subject: mackermit through a tac
Date: Fri, 16-Nov-84 06:14:22 EST
Article-I.D.: uw-beave.2252
Posted: Fri Nov 16 06:14:22 1984
Date-Received: Sat, 17-Nov-84 04:16:23 EST
Sender: yenbut@uw-beave
Lines: 27
For those interested,
I connect into an ARPA TAC here in the Dallas area and connect to USC-ECLB
where I have an account. I have been able to transfer .HEX and .DL files
without problems. But .RSRC file transfer had been out of reach.
I formed a question and mailed to info-mac but it was either never
received or never posted. Maybe this message will make it onto the
BBoard.
I have figured out how to transfer executable images up and down through
an ARPA TAC. I call into the local TAC at 1200 baud, 8-bits, no parity.
The commands that you must give the TAC are:
@B O S
@B I S
I do not know what it does, however it does work. Macintosh Kermit can
transfer 8 bit data after executing this command. Note that @B I S causes
the '@' to lose any significance so this must be the last command that
you execute. Also, nothing else must be done. No special commands to
kermit, at either end. When you logout from the host at the other end of
the TAC the '@' regains its significance.
Stewart French
french%ti-eg @ csnet-relay
