Path: utzoo!watmath!clyde!burl!mgnetp!ihnp4!houxm!houxz!vax135!cornell!uw-beaver!info-mac
Subject: Re: Apparent MacTerminal BUG
Date: Fri, 10-Aug-84 19:56:56 EDT
Article-I.D.: uw-beave.1446
Posted: Fri Aug 10 19:56:56 1984
Date-Received: Sat, 11-Aug-84 03:01:21 EDT
Lines: 26
I've never actually tested it on the USR Password I use, but on a REAL
Hayes modem, the +++ sequence must be preceded and followed by a full
second (default, is adjustable, I think) of no data to prevent just
this sort of confusion. If the USR/Apple doesn't do this, then Apple
has screwed up. Probably the people writing MacTerminal use a real
Hayes, since it's so much better (personal opinion, of course); that
might explain why MacTerminal doesn't do some of the things that it
wouldn't have to do if you were using a Hayes instead of a USR/Apple.
joe
Return-Path:
Received: from CMU-CS-SPICE.ARPA by SUMEX-AIM.ARPA with TCP; Thu 9 Aug 84 14:51:15-PDT
Date: Thursday, 9 August 1984 17:46:12 EDT
To: Joseph I.Pallas
cc: [email protected]
According to the manual for my USR Autodial, it also requires a full second
of silence before and after the sequence. Although the length is fixed, you
can change the "+++" to any other sequence of three identical characters.
-- tdn
