Splat Pack Installer for Macintosh
Download: http://archive.info-mac.org/cfg/splat-pack.hqx
The Splat Pack Installer for Macintosh is an AppleScript utility that
automatically extracts the files needed from the Carmageddon 'Splat
Pack' CD and installs the files along with a copy of Carmageddon to make
the Carmageddon 'Splat Pack' add-on playable on the Macintosh.
Installation of the Splat Pack will require about 350-400MB of free
space on a 1GB hard drive without HFS+. Drives larger than 1GB may need
free space.
Please note that you can not install the Carmageddon 'Splat Pack' add-on
without the original Carmageddon CD.
This utility has only been tested with AppleScript for MacOS 8.
