ZAPPED! (on Halloween, yet)
Path: utzoo!watmath!clyde!burl!ulysses!cbosgd!ihnp4!houxm!hogpc!houti!ariel!vax135!cornell!uw-beaver!info-mac
Subject: ZAPPED! (on Halloween, yet)
Date: Thu, 1-Nov-84 20:53:32 EST
Article-I.D.: uw-beave.2068
Posted: Thu Nov 1 20:53:32 1984
Date-Received: Sat, 3-Nov-84 02:37:06 EST
Sender: yenbut@uw-beave
Lines: 22
I was inputting a large MacDraw document, and had been working for a few hours
with the disk spinning continually as MacDraw swapped. Suddenly there was a
very bright blue flash from the front of the Mac, and a slight "pop", and the
disk stopped spinning and the mouse locked up. I hit the reset switch, fearing
the worst, but MacDraw and my document were still on disk; however, a lot of
the more recently added parts had gone away. I'm not sure whether data was
actually lost or I just hadn't been saving as often as I thought.
I could see a spot about 1/2 mm diameter on the media surface by holding it up
to the light; but the Verify command in Disk Utility claimed everything was
okay. I made a copy of the disk with Disk Copy just to be sure; no difference.
The Mac and the drive are obviously still working.
What must have happened was the disk (a Sony) had been spinning so long that it
(or some part of the drive) built up a static charge and eventually sparked!
The weather hasn't been especially dry; I hate to think about what might happen
in the winter when the steam heat comes on. I'm buying Maxell disks now anyway
because they're cheaper, but should probably talk to Sony and Apple....
--Mike Rubin
