Download: http://archive.info-mac.org/cfg/sound-t ... ger-10.hqx
SoundThemeChanger is an application which allows you to change Sound
Sets used in MacOS 8.5. Besides the ability to change Sound Sets you
can also record your own sounds for use in the soundset (max 10 sec.).
The registered version even lets you extract sounds from files, if
these sounds are stored in the snd resource. For example it is
possible to extract sounds from different sound sets and to create
your own sound set with it.
Because it is very hard to get all sound resources documented,
SoundThemeChangers has a section with undefined resources, these are
sounds in the theme file which don't have a name or category assigned
yet. However SoundThemeChanger has the unique capability to add sound
resources, all you have to do is give a unique resource number (the
resource number has to be used by the system otherwise it will never
be played) name and assign it to a category.
System requirements :
PowerPC
Memory 2 MB
Mac OS 8.5 or Mac OS 8.1 + soundset file
Rgds,
Yves
