SoftwareFPU 3.07
SoftwareFPU 3.07
Post by Info-Mac » March 12th, 1999, 11:00 am
Download: http://archive.info-mac.org/cfg/software-fpu-307.hqx
SoftwareFPU is a freeware Macintosh utility which allows applications
requiring a Floating Point Unit (FPU) to work on computers without one,
such as the IIsi, IIvi, LC series, Classic II & Color Classic series,
Performa series, Power Macintosh, and some models of PowerBook, PowerBook
Duo, and Quadra series. Drop this control panel onto your System folder
and FPU applications that formerly crashed will begin working. SoftwareFPU
requires a 68020, 68030, 68LC040, or PowerPC processor.
SoftwareFPU 3.07 is compatible with System 8.5 and fixes an
incompatibility with Epson Stylus print drivers.
