Left vent getting hot
Post by Info-Mac » November 14th, 1984, 9:14 am
Subject: Left vent getting hot
Date: Wed, 26-Sep-84 15:25:48 EDT
Article-I.D.: uw-beave.1786
Posted: Wed Sep 26 15:25:48 1984
Date-Received: Thu, 4-Oct-84 02:19:45 EDT
Sender: root@uw-beave
Lines: 20
Mine does that too. I think it's to be expected since the power
supply is right under there; according to some early information on
the power supply, the first machines (including the present ones,
I presume) used a conventional, non-switching power supply due to
some problem Apple had with getting the switching power supply out
in time. If so, that would explain part of it, since I think it would tend
to get hotter than a switching power supply would. In any case,
there's a note on page 135 of the plain User's Manual in the section
entitled "keeping it in good shape/main unit" which says "The top
of the main unit will feel warm to the touch (about 85 - 90 degrees
F.) after it's been on for awhile."
Right now as I write this, mine has a temperature of 102 degrees
F. measured by putting a desktop thermometer face down on top of
the left vent until it became stable. That's with a room temp-
erature of about 78 degrees.
-- Eric Roskos
jer%vanderbilt@csnet-relay
