Re: debugging icons
Re: debugging icons
Path: utzoo!linus!decvax!ucbvax!ucbcad!tektronix!uw-beaver!info-mac
Subject: Re: debugging icons
Date: Sun, 1-Jul-84 13:02:28 EDT
Article-I.D.: uw-beave.1016
Posted: Sun Jul 1 13:02:28 1984
Date-Received: Wed, 4-Jul-84 00:24:11 EDT
Lines: 40
I tried using the Resource Mover to edit bad icons out of the Desk Top,
as was suggested, with only partial success. At first I was using a new
author-identifier for each new try at an icon, but this seems wasteful
and would probably require eventually building a new desktop when it
becomes too full.
My original strategy for using rmover was to throw away the application with
the old icon, or turn off the bundle bit using Set File if the application
already had the new icon (but was showing the previous version), then go
into rmover on the Desk Top, and cut out the resource named by the author
string (ie, CCOM, or safer, TEST). When the bundle bit was turned back on,
the new icon did appear, but unfortunately the previous mask was still there.
I believe removing one of the ICN# resources would solve the problem, but
don't have any idea which one to remove (there were about 16 ICN# resources
on the disk I was playing with). I did try cutting out all of them (pasting
them in a handy MacTerminal document), but this resulted it a "Ghost Disk"
where all of the fancy icons had vanished, and I couldn't get them to come
back using the usual Bundle Bit trick. They did return when I pasted the
resources back into the desk top, but it still gave me the bad mask . . .
back where I started. (the folder, generic document, and generic application
or "hand" icons are probably in the System file -- only they survived without
any ICN# resources in the DeskTop). The disk was also in bad shape after this
ordeal; with a messed up free list, it eventually had to be erased.
Until someone figures out how the Finder maps reference idents, the best way
might be to debug icons on a scratch disk with no folders and only MacTerm,
SetFile, and the application being worked on, so you could blow away the
DeskTop any time without much pain. Then once the icon is finished, move it
to a more stable disk.
Nicer would be a version of the icon editor that could install the icon
directly into the application's resource (and the finder?), so we don't
have to muck about sending the icon to the VAX, installing it in the .rc
file, rebuilding the application, and sending it back to the Mac again.
Even a utility that would do nothing but install icons into applications
would be better than the current situation.
Dave Johnson
