dragging with lasso
dragging with lasso
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!ihnp4!zehntel!hplabs!tektronix!uw-beaver!info-mac
Subject: dragging with lasso
Date: Wed, 29-Aug-84 01:16:51 EDT
Article-I.D.: uw-beave.1551
Posted: Wed Aug 29 01:16:51 1984
Date-Received: Sat, 25-Aug-84 06:21:38 EDT
Lines: 21
I'm doing some animation of irregularly shaped objects myself. I rely
mainly on the QuickDraw CopyBits routine which can do its copying
clipped to a region. In other words, it can copy an arbitrary region
from one place to another. So when moving an irregularly shaped
object, I keep a copy of the object in an offscreen bitmap. To draw
the object, I first save the bits it will cover in another offscreen
bitmap. Then I use CopyBits to transfer the offscreen image of the
object to the screen, clipping to the boundary of the object. To move
the object, I replace the saved bits, save the soon-to-be-covered bits,
and CopyBits it to its new position. This method gives reasonably fast
and smooth animation of small objects using very little offscreen
memory (less than 100 bytes for my application).
Now, as a matter of fact, my animation is not as fast or smooth as Bill
Atkinson's (small wonder). Part of that is explained by my writing in
C and his writing in assembly. But he might be (and knowing him,
probably is) using a smarter algorithm. He did say he keeps several
copies of the entire screen around to let him do undo, which may allow
methods not possible with very little offscreen memory.
