Shtdown Controller 2.0.1 68k
Download: http://archive.info-mac.org/cfg/shutdow ... 01-68k.hqx
A CONTROLLED WAY TO AUTOMATICALLY SHUTDOWN YOUR MAC
Shutdown Controller provides as the name suggest a 'controlled' way to
shutdown unattended Macs.
Using Shutdown Controller you can as example start a download of a large
file via internet and leave your Mac, when the download will finish,
Shutdown Controller shutdown your Mac automatically.
You can also use Shutdown Controller on a server and set it to shutdown
only if some application indicated as 'critical' ultimated their work and
only if a specified time was reached.
Shutdown Controller uses a friendly Mac interface, it can inform you of
the upcoming shutdown flashing a different mark in its status window
depending of the situation, and if in background using the OS Mac
notification manager flashing an icon in the menu bar.
Requires System 7 or System 8.
This is the 68k version.
Further info at
*Inclusion in CDROM permitted*
