sherlock-purified-1.0.hqx
Download: http://archive.info-mac.org/cfg/sherloc ... ied-10.hqx
Sherlock Purified 1.0
11/23/99
Don't you like the Quicktime-style interface of Sherlock 2? No? Well now you
can change Sherlock 2 to look like Sherlock 1, and also remove the banners!
>From an author who remains anonymous by request. This patch only works with
the unmodified copy of Sherlock 2 included in Mac OS 9. I am not responsible
for the results of applying this patch.
This patch may be included on all media at no charge. See also Sherlock
nobanners 2.0. Visit my web page for more information:
http://www.bol.ucla.edu/~awatters
- Andrew Watters
