macput.c, version for Beta MacTerm
Post by Info-Mac » September 23rd, 1984, 12:02 am
Subject: macput.c, version for Beta MacTerm
Date: Thu, 2-Aug-84 19:12:30 EDT
Article-I.D.: uw-beaver>.1380
Posted: Thu Aug 2 19:12:30 1984
Date-Received: Sat, 4-Aug-84 02:15:09 EDT
Lines: 476
Here is the source for the current incarnation of macput . . . .
It is now compatible with the 0.5 Beta version of MacTerminal, and
in case you still need to use the -0.15X version, there's the "-o"
option to provide compatibility. Some minor bug fixes have been
made, as well as a couple of changes for portability to non-4.2
systems. Please pass any improvements/bug fixes on to me, and
if you know of any good protocols for use on a flow-controlled
line, let me know.
Dave Johnson
ddj%[email protected]
Brown University Computer Science
cut here
#include
#include
#include
#include
#include
#include
#include
#include
/* Mac time of 00:00:00 GMT, Jan 1, 1970 */
#define TIMEDIFF 0x7c25b080
#define RECORDBYTES 132
#define DATABYTES 128
#define NAMEBYTES 63
#define RETRIES 10
#define ACKTIMO 10
#define MAXRECNO 0xff
#define BYTEMASK 0xff
#define TMO -1
#define DUP '\000'
#define SOH '\001'
#define EOT '\004'
#define ACK '\006'
#define NAK '\025'
#define CAN '\030'
#define EEF '\032'
#define ESC '\033'
#define H_NLENOFF 1
#define H_NAMEOFF 2
/* 65 80 is the FInfo structure */
#define H_TYPEOFF 65
#define H_AUTHOFF 69
#define H_LOCKOFF 81
#define H_DLENOFF 83
#define H_RLENOFF 87
#define H_CTIMOFF 91
#define H_MTIMOFF 95
#define H_OLD_DLENOFF 81
#define H_OLD_RLENOFF 85
#define TEXT 0
#define DATA 1
#define RSRC 2
#define FULL 3
int mode, txtmode;
int pre_beta; /* -o flag; for compatibility with MacTerminal Version -0.15X */
struct macheader {
char m_name[NAMEBYTES+1];
char m_type[4];
char m_author[4];
long m_datalen;
long m_rsrclen;
long m_createtime;
long m_modifytime;
} mh;
struct filenames {
char f_info[256];
char f_data[256];
char f_rsrc[256];
} files;
int recno;
char buf[DATABYTES];
* macput -- send file to macintosh using xmodem protocol
* Dave Johnson, Brown University Computer Science
* (c) 1984 Brown University
* may be used but not sold without permission
* created ddj 6/17/84
* revised ddj 7/16/84 -- protocol changes for MacTerminal Beta Version 0.5X
* revised ddj 7/31/84 -- pre-4.2 signal bugs fixed in timedout()
* revised ddj 7/31/84 -- fixed timeout problem in initial handshake
char usage[] =
"usage: \"macput [-o] [-rdu] [-t type] [-a author] [-n name] filename\"\n";
main(ac, av)
char **av;
int n;
char *filename;
if (ac == 1) {
fprintf(stderr, usage);
exit(1);
mode = FULL;
ac--; av++;
while (ac) {
if (av[0][0] == '-') {
switch (av[0][1]) {
case 'r':
mode = RSRC;
strncpy(mh.m_type, "APPL", 4);
strncpy(mh.m_author, "CCOM", 4);
break;
case 'u':
mode = TEXT;
strncpy(mh.m_type, "TEXT", 4);
strncpy(mh.m_author, "MACA", 4);
break;
case 'd':
mode = DATA;
strncpy(mh.m_author, "????", 4);
break;
case 'n':
if (ac > 1) {
ac--; av++;
n = strlen(av[0]);
if (n > NAMEBYTES) n = NAMEBYTES;
strncpy(mh.m_name, av[0], n);
mh.m_name[n] = '\0';
break;
else goto bad_usage;
case 't':
if (ac > 1) {
ac--; av++;
strncpy(mh.m_type, av[0], 4);
break;
case 'a':
if (ac > 1) {
ac--; av++;
strncpy(mh.m_author, av[0], 4);
break;
case 'o':
pre_beta++;
break;
default:
bad_usage:
exit(1);
else {
filename = av[0];
ac--; av++;
setup_tty();
find_files(filename, mode);
if (mode != FULL)
forge_info();
if (send_sync() == ACK) {
txtmode = 0;
send_file(files.f_info, 1);
if (mode != FULL)
unlink(files.f_info);
if (mode == TEXT) txtmode++;
send_file(files.f_data, 1);
txtmode = 0;
send_file(files.f_rsrc, 0);
reset_tty();
char *filename;
int n, tdiff;
struct tm *tp;
struct timeb tbuf;
struct stat stbuf;
sprintf(files.f_data, "%s.data", filename);
sprintf(files.f_rsrc, "%s.rsrc", filename);
if (mode == FULL) {
sprintf(files.f_info, "%s.info", filename);
if (stat(files.f_info, &stbuf) != 0) {
perror(files.f_info);
cleanup(-1);
return;
else {
strcpy(files.f_info, "#machdrXXXXXX");
mktemp(files.f_info);
if (mode == RSRC) {
strcpy(files.f_data, "/dev/null");
if (stat(files.f_rsrc, &stbuf) != 0) {
strcpy(files.f_rsrc, filename);
perror(files.f_rsrc);
cleanup(-1);
mh.m_datalen = 0;
mh.m_rsrclen = stbuf.st_size;
else {
strcpy(files.f_rsrc, "/dev/null");
if (stat(files.f_data, &stbuf) != 0) {
sprintf(files.f_data, "%s.text", filename);
strcpy(files.f_data, filename);
perror(files.f_data);
cleanup(-1);
mh.m_datalen = stbuf.st_size;
mh.m_rsrclen = 0;
if (!pre_beta) {
ftime(&tbuf);
tp = localtime(&tbuf.time);
tdiff = TIMEDIFF - tbuf.timezone * 60;
if (tp->tm_isdst)
tdiff += 60 * 60;
mh.m_createtime = stbuf.st_mtime + tdiff;
mh.m_modifytime = stbuf.st_mtime + tdiff;
if (mh.m_name[0] == '\0') {
n = strlen(filename);
strncpy(mh.m_name, filename, n);
forge_info()
int n;
char *np;
FILE *fp;
for (np = mh.m_name; *np; np++)
if (*np == '_') *np = ' ';
buf[H_NLENOFF] = n = np - mh.m_name;
strncpy(buf + H_NAMEOFF, mh.m_name, n);
strncpy(buf + H_TYPEOFF, mh.m_type, 4);
strncpy(buf + H_AUTHOFF, mh.m_author, 4);
if (pre_beta) {
put4(buf + H_OLD_DLENOFF, mh.m_datalen);
put4(buf + H_OLD_RLENOFF, mh.m_rsrclen);
else {
put4(buf + H_DLENOFF, mh.m_datalen);
put4(buf + H_RLENOFF, mh.m_rsrclen);
put4(buf + H_CTIMOFF, mh.m_createtime);
put4(buf + H_MTIMOFF, mh.m_modifytime);
fp = fopen(files.f_info, "w");
if (fp == NULL) {
perror("temp file");
cleanup(-1);
fwrite(buf, 1, DATABYTES, fp);
fclose(fp);
send_sync()
int c, i;
for (i = 0; i 0) {
for (i = 0; i > 24) & BYTEMASK;
value <<= 8;
*bp++ = c;
