Path: utzoo!watmath!clyde!burl!ulysses!mhuxj!houxm!hogpc!houti!ariel!vax135!cornell!uw-beaver!info-mac
Subject: macput problem
Date: Thu, 11-Oct-84 20:39:41 EDT
Article-I.D.: uw-beave.1894
Posted: Thu Oct 11 20:39:41 1984
Date-Received: Sat, 13-Oct-84 06:27:26 EDT
Lines: 15
I'm using beta MacTerminal (version 0.15X) with the appropriate version
of macput, over a 1200 baud modem. As soon as I try to start a
transfer, I get an error box thrown up which says "GetInfo: Got
BadResult from GetBlock", and the transfer fails. Then I have to wade
through a bunch of macput output.
What can the problem be? The other system is a VAX running 4.2 BSD. I
don't see how it can be a line noise problem, since macget seems to
work all the time. I'm directly connected (no network connections), so
I don't see how it can be a flow control problem either. When I try
this onsite at 9600 baud, it usually works, though once or twice I've
had it fail the same way. Any explanations?
- Mike
