Sherlock nobanners 2.0- French
Download: http://archive.info-mac.org/cfg/sherloc ... -20-fr.hqx
2/20/00
This is a simple ResCompare patch that removes all banners from the French
version of Sherlock 2 (actually version 3.0.1, included with Mac OS 9). The
patch will only work with Sherlock 2. To remove banners from earlier
versions, download Sherlock nobanners 1.0.
Most banner programs simply alter the search plugins in your system folder;
this one modifies three resources in the Sherlock 2 application itself,
displaying only gray space instead of some idiotic banner. If you would
rather make the modifications yourself, my web site has the instructions:
http://www.awatters.com
Use this program at your own risk. I am not responsible for the
consequences. This program is free and may be distributed on all media for
non-profit use only. For-profit users should contact the author.
- Andrew Watters
