XLISP
XLISP
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!ihnp4!houxm!houxz!vax135!cornell!uw-beaver!info-mac
Subject: XLISP
Date: Fri, 17-Aug-84 19:31:28 EDT
Article-I.D.: uw-beaver>.1502
Posted: Fri Aug 17 19:31:28 1984
Date-Received: Sun, 19-Aug-84 03:26:13 EDT
Lines: 41
I've been working on a stdio package for the Mac; it
works reasonably well, but I haven't fully tested it yet.
I have implemented the binding of suitable enhanced _iobuf
structures to Macintosh windows; all the normal stdio
operations are supported. The application agrees to call
a Listen routine very often; Listen handles all the usual
update, activate, mouse-down, and key-down events. Intelligent
scroll-bar support is included. Listen will deal with
windows that have an associated FILE pointer; other
windows are handled by user-specified routines.
The implementation details are rather complicated
and I don't want to make any promises until the package
is ready for release, but I do have a couple of questions:
(1) I modeled many of my event-handling routines
after the FILE code given as an example program in Inside
Mac. Has anyone out there noticed that the whole input
line flashes when you hold a key down? It looks like
everything from the line start to the character that's
just been TEKey'ed gets updated. The effect is particularly
annoying when one tries to backspace repeatedly (by holding
the key down.) Am I doing a spurious TEUpdate? Does
anyone know exactly which TextEdit routines generate
update events, and which parts of the window are bundled
into the update region? (It seems that TextEdit is causing
the whole line to be re-drawn, not just the last position.)
MacWrite doesn't exhibit that flashing behaviour.
(2) I am fiddling with a Macintosh implementation
of XLISP, the minimal object-oriented Lisp interpreter
released on net.sources a while back. I haven't done
a thorough investigation yet, but here's the bug: XLISP
launches without incident, sets up the interpreter window,
and cogitates for a couple of seconds. Then I hear
the infamous bell and the system reboots WITHOUT GIVING
ME THE USUAL ALERT BOX. Does anyone have any suggestions?
R. Martin Chavez ([email protected])
