Mac Font Editor
Mac Font Editor
Post by Info-Mac » September 23rd, 1984, 12:53 am
Path: utzoo!watmath!clyde!burl!ulysses!mhuxl!ihnp4!houxm!houxz!vax135!cornell!uw-beaver!info-mac
Subject: Mac Font Editor
Date: Mon, 6-Aug-84 18:31:59 EDT
Article-I.D.: uw-beaver>.1404
Posted: Mon Aug 6 18:31:59 1984
Date-Received: Wed, 8-Aug-84 19:07:11 EDT
Lines: 89
From [email protected] Mon Aug 6 15:31:36 1984
[HOO, BOY]
So, there I was, with the Font Editor newly in my possesion, having spent the
last several months getting sick of not being able to tell the difference
between a 0 and a O, or a I and a l. AHA, says I, I will edit the Monaco
Font and cross that zero and serif that I. So I did. Then I tried to
install it in the system file. OOPS, Monaco 9 is a system font. Can't
remove it with the Font Mover. So I removed it with the Resource Mover,
then used the Font Mover to put the new font in. Started feeling good.
Then I noticed that the System File I was using was one of the old ones.
No Matter, says I, I will just do it again on one of the New System Files.
Ho HO. It seems that the Resource Mover will not allow you to modify the
System FIle if you happen to have booted with the new System File. So
I booted under the old System File, renamed the new System File, removed
the Monaco Fonts, renamed it once again "System" and stuck the new fonts
in.
Here are the steps:
Copy the font editor, resource mover, the new System Folder, and the fonts
file that came with the new System Folder to a work disk.
enter the Font Editor, edit the font(you gotta figure that one out for
yourself).
install the fonts (I did Monaco 9 & 12)
exit the Font Editor
trash everything except the system file, the fonts file, and the resource
manager - empty the trash
DUP the System disk
Reboot with another disk as the startup disk
rename "copy of System Disk" as "foo" (or whatever) (can't do this without
the reboot)
copy *OLD* System file and Finder from another disk
reboot with work disk as startup disk
use resource mover to clear Monaco fonts from "foo" (Monaco fonts are 512,
521, & 524)
exit resource mover
reboot with some other disk as startup disk
trash system file on work disk - empty trash
rename "foo" as "System"
Use Fontmover to move new Monaco fonts into System
reboot from workdisk
copy System file to destination disk
test with macTEP and Macwrite
jubilate
copy System file to *ALL* your disks
Notice that Macterminal is still using the old font (I just now noticed)
Back to the resource mover...
>>>>>>NOTE<<<<<<<<<
The utilities from the software supplement may work great on a Lisa (don't
know, don't got one) but on the Mac, they have a way of crashing the system
and/or trashing the disks. SO, don't use them on anything valuable, and
BACKUP, BACKUP, BACKUP!!
Disclaimer: There is no guarantee that this procedure will work for you.
In fact there is no guarantee that this procedure worked for me. All I
know is that I can run MacTEP (and expect to run Macterminal) and see crossed
0's and serifed I's. If you have any problems, give me a call, and let's
talk about it.
Michael Ward, NCAR/SCD
UUCP: {hplabs,nbires,brl-bmd,seismo,menlo70,stcvax}!hao!sa!ward
ARPA: hplabs!hao!sa!ward@Berkeley
BELL: 303-497-1252
USPS: POB 3000, Boulder, CO 80307
