NEW MacWrite info
NEW MacWrite info
Path: utzoo!watmath!clyde!burl!mgnetp!ihnp4!houxm!vax135!cornell!uw-beaver!info-mac
Subject: NEW MacWrite info
Date: Fri, 7-Sep-84 22:31:44 EDT
Article-I.D.: uw-beave.1664
Posted: Fri Sep 7 22:31:44 1984
Date-Received: Thu, 13-Sep-84 07:19:34 EDT
Lines: 29
I played with a version of the new MacWrite and can report on a
version that existed 1 month ago; any of these parameters might
have changed since then.
The file format is different from the old MacWrite's; when you open an
old MacWrite, you must confirm a "Converting format" dialogue box.
The encoding is sufficiently obscure that you CAN'T read the text by
looking at the ASCII with utilities like "Examine File", which I found
frustrating in an emergency. There are various reasonable limits,
like "can't Cut or Copy more than 100 paragraphs", but of course much
less severe than old MacWrite's.
There are just a few improvements: the page number appears cutely
inside the scroll elevator, even when you're dragging it; Find Next is
wired to clover-f, and Goto Page is wired to clover-g. There is also
a "6 lines per inch" toggle, which, though ugly, makes better use of
the screen by stacking lines slightly closer.
It is actually SLOWER than the old MacWrite on floppies, since it uses
the disk more. It was painfully slow with a single-floppy
configuration. It was very nice with a Corvus hard disk though.
There were bugs in the version I played with, including some the
implementors were aware of "in the vicinity of disk full". Some were
serious enough to generate an emergency, so I don't recommend anyone
who comes across the same "NEW MacWrite" use it for serious work. It
will be very nice when it's debugged, though.
