File usage in MacPascal
Subject: File usage in MacPascal
Date: Tue, 21-Aug-84 04:09:39 EDT
Article-I.D.: uw-beaver>.1525
Posted: Tue Aug 21 04:09:39 1984
Date-Received: Wed, 22-Aug-84 01:11:56 EDT
Lines: 21
We will be using MacPascal as the coding tool for the first two
undergraduate course in CS. This requires that students turn in assignments
by presenting a listing of their program, a listing of the test data on which
it was run, and the output produced. In order to achieve these goals we
have, in the past, used the file i/o available in Pascal. Can this be done
in MacPascal?
I have been unable to find any documentation which asserts or denies the
existance of file handling capabilities. Specifically,
1 - Can files be created under program control? If so, where may I find
a description of the syntax for doing so?
2 - Can a file be read under program control? If so , ...
3 - Is it possible to print a file created by a MacPascal program using
the print facility inside the MacPascal file window?
Any inforamtion would be greatly appreciated. Don
