Mac speaker
Mac speaker
Posting-Version: version B 2.10.2 9/18/84; site qumix.UUCP
Path: utzoo!watmath!clyde!bonnie!akgua!mcnc!decvax!decwrl!amd!qumix!len
Subject: Mac speaker
Date: Sun, 28-Oct-84 19:16:23 EST
Article-I.D.: qumix.147
Posted: Sun Oct 28 19:16:23 1984
Date-Received: Sat, 3-Nov-84 08:21:58 EST
Distribution: net
Organization: Qume Corp., San Jose, CA
Lines: 25
Apple says not to try hooking up a large speaker directly to the jack
in the back since the Mac isn't supposed to be able to drive that much
of a load. Well, not having "inside Mac" and not knowing better I
decided to try anyway.
First I tried using a cheap transistor radio as an amplifier and
hooking up a 4" low compression car speaker that I had laying around.
The results were terrible, even without the Mac. It could barely drive
the speaker. Then I tried matching it to the Mac. After an hour of
trying different resistor and capacitor combinations I gave up. The
Mac severly overdrived the radio input.
Then I hooked the 4" speaker directly to the Mac. The results were
astounding. Plenty of volume and very little distortion. I used extra
parts on hand i.e. I took a tv earphone set and cut the earphone off.
Just about anything will do. The speaker came in a plastic enclosure
which seems to help the sound quality. This is portable and a lot
better than lugging my stereo out to the garage.
Note: If you decide to try this. The secret seems to be the 4" low
compression speaker. I don't guarantee the results if you try anything
larger.
