Re: TEKALIKE terminal emulator for the MAC
Subject: Re: TEKALIKE terminal emulator for the MAC
Date: Wed, 19-Sep-84 11:37:08 EDT
Article-I.D.: uw-beave.1733
Posted: Wed Sep 19 11:37:08 1984
Date-Received: Tue, 25-Sep-84 19:35:37 EDT
Lines: 29
There ARE, however some minor problems with the first TEKALIKE release:
(1) The flow control (I've tried both "send" and "full") is inadequate when
using the "record" function at speeds higher than about 1200 baud. The result
is misplaced vectors.
(2) The "record" function is sensitive to either file size or data (I don't know
which, yet), causing only the first portion of a recorded file to play back.
I've seen this problem on 70KB files whereas 20KB files seem to have no problem.
(3) There are no fonts supplied which are suitable for normal terminal usage.
All fonts are variable-width so nothing lines up.
(4) No mention is made as to how to generate ` and ~ characters from the
keyboard. ~ generates RUBOUT, ` generates ESC and COMMAND-` generates a BREAK.
Ever tried living without a tilde under the Software Tools or BSD?
Other than the above problems, the package is extremely nice. Anyone who is
looking at VT-100/TEK emulating terminals may wish to consider a Mac with
MacTerminal and TEKALIKE instead. Now if only the functions of both were
combined into a single package so it didn't take 30 seconds to switch between
VT-100 and Tektronix emulation...
(By the way, TEKALIKE drops to $125 at about the 50pc. level)
dpm
