ScannerProbePlus 2.0
Download: http://archive.info-mac.org/cfg/scanner ... lus-20.hqx
ScannerProbePlus helps overcome some of the difficulties associated
with the use of Apple(r) Scanners. Applications which perform scanning chores
using scanners, such as those made by Apple Computer(r), rely on a driver
which is installed into the memory of the computer at boot time. Sometimes
this does not happen and, as a result, applications cannot communicate
with the Scanner due to the missing driver. The net result is that you
cannot perform any scanning until the driver is in place and it has
successfully communicated with the Scanner. ScannerProbePlus is only
meant to work with scanners that are connected via a SCSI bus - not USB.
